Posted March 11, 201114 yr comment_348875 I did an oil change on my Z the other day and noticed a spring sticking out next to the neck for my oil filter. It turns out that it was the internals for a ball valve that helps regulate the oil flow into the oil filter. Anyway the problem I'm having is getting the remains of the regulator out of the block. An extractor is too long and pick tools are too big. I was thinking of getting a bolt that fit and trying to get it out with that? Does anyone have experience with removing these and if so what. Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/ Share on other sites More sharing options...
March 11, 201114 yr comment_348877 What happened to the ball? I think that is your pressure relief valve, it comes in to play if your filter gets plugged up and won't flow enough oil.I got curious and looked in the FSM. It says to pry it out with a screwdriver and install the new one by tapping it in. If you had the new one in hand, things might make sense.Page EL-4. Edited March 11, 201114 yr by Zed Head Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348877 Share on other sites More sharing options...
March 11, 201114 yr Author comment_348913 I do have the new one I'm trying to figure out how to remove the old one since all that is left is the outer shell, I've tried an extractor but there something at the end that prevents me from being able to fit it in all the way. Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348913 Share on other sites More sharing options...
March 11, 201114 yr comment_348917 Just plug the hole with a pipe plug and forget it. Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348917 Share on other sites More sharing options...
March 11, 201114 yr comment_348921 What Zforce said. You'll get full oil filtering with that one mod. It's covered in the 'Modify Your Nissan\Datsun' book. You need only keep up with oil and filter changes. Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348921 Share on other sites More sharing options...
March 11, 201114 yr Author comment_348935 get a pipe plug at home depot or what? Also part of the relief valve is still inside will that matter? Edited March 11, 201114 yr by OniZ Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348935 Share on other sites More sharing options...
March 12, 201114 yr comment_348970 OniZ said: get a pipe plug at home depot or what? Also part of the relief valve is still inside will that matter?I doubt it. Link to comment https://www.classiczcars.com/forums/topic/38856-oil-filter-regulator/#findComment-348970 Share on other sites More sharing options...
