Be honest, hold off till you can afford a good body 2Gs isn't going to give you that. If you don't want to do the body work it won't take much to go over what a restored car will go for just replacing the floor pans or even just getting 3-4 rust spots repaired properly will run you over.
I don't mind doing doors or fenders or hood or hatch or floor pans. Guess I should have put that out there really looking for straight roof, and quarters since they need cut and welded any piece that unbolts isn't a concern and floor pans I don't mind since they can't be seen. Just don't feel comfident enought to cut and blend panels.
well guys here it is. I was about to give up and take a break from looking and last night I checked out south jersey on craigslist. And found this gem. Needs two fenders and some rust around the gas cap fixed. Also has the traditional fram rot. So not to bad but have some work drove it on the trailer so thats a plus but it has a dead cylinder the black smoke would lead me to beleive that it needs a standard tune up. Plugs, wires, cap and rotor. So wish me luck but I'm back in the game :)
