Posted March 18, 201114 yr comment_349782 I have a 77-79 wide ratio early five speed that won't go/stay in fith gear. From what I have read that usually signifies a bad syncros, gear/bearing free play, or ball and detent spring. Unfortunately, the kits available from Drivetrain.com and other google searches don't contain the 5th gear fiber ring syncro. I spent awhile at the dealership and they couldnt help either. Has anyone got a lead on that part or will I be stuck rebuilding one of my 3 four speeds?On a side note, I think I have the stock 3.364 rear end and I guess the five speed gearing isn't favorable in that combination. Link to comment https://www.classiczcars.com/forums/topic/38940-where-to-get-5-speed-fiber-ring-syncro/ Share on other sites More sharing options...
March 21, 201114 yr comment_350186 Eddie Radatz or John Williams in Atlanta might know...search their names here for phone numbers. Link to comment https://www.classiczcars.com/forums/topic/38940-where-to-get-5-speed-fiber-ring-syncro/#findComment-350186 Share on other sites More sharing options...
March 22, 201114 yr comment_350235 They are still available although you will probably have to buy a kit that comes with more than judt the part you need. That's good though, it allows you a chance to have everything taken care of while it is on the bench. The same thing happened to me and my mechanic rebuilt it for me. He races 510's on the SCCA circuit so he knew exactly where to go to get what he needed. Try AAMCO. They should have enough parts suppliers to get what you need. Link to comment https://www.classiczcars.com/forums/topic/38940-where-to-get-5-speed-fiber-ring-syncro/#findComment-350235 Share on other sites More sharing options...
March 22, 201114 yr Author comment_350299 I was planning on buying a full set of bearings and syncros as is. I will dig into looking up those numbers after work. Thanks for your help. Link to comment https://www.classiczcars.com/forums/topic/38940-where-to-get-5-speed-fiber-ring-syncro/#findComment-350299 Share on other sites More sharing options...
