Throttle shaft doesn't line up - What am I missing?
Harry Walker
After looking at all the posts and thinking I will stay with the Webers for now it looks like I will go with the bracket mod. Attached is the instruct sheet from Weber that I used to install these back on '91. I think the transmission mounting bushing is bigger than it was before and is the cause of the problem. Thanks to everyone for the help. I hope to have my Z running by the end of the summer. You never know with all the other stuff life makes you do but that is the goal.
Lokar Throttle Cable Kit - I'm getting ready to purchase one as well..........Harry' date=' by the way - great to have you on the forum. Original owner!!
[url']http://www.racingonthecheap.com/throttle-linkage-vs-throttle-cable/
+1 for Lokar's throttle kit. Had mine purchased with black anodized fittings :)
24" looks like the correct length, I used a 36" because my pedal is on the wrong side :stupid:
Edited by spitz17
