Posted March 22, 201114 yr comment_350219 I have heard that if you twist a piston ring you can tell if it is bad.cant remimber if it was supposed to bend or break..any ideas? Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/ Share on other sites More sharing options...
March 22, 201114 yr comment_350380 Reusing piston rings is like reusing a condom. Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/#findComment-350380 Share on other sites More sharing options...
March 23, 201114 yr comment_350475 Reusing piston rings is like reusing a condom.So you will have to turn the piston ring inside/out ? Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/#findComment-350475 Share on other sites More sharing options...
March 24, 201114 yr comment_350541 So you will have to turn the piston ring inside/out ?Yeah your going to get some blow-by ha ha. Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/#findComment-350541 Share on other sites More sharing options...
March 24, 201114 yr Author comment_350542 not talking about reusing, just seeing if they were bad or not.twist the ring 180 degree, obviously there is no sense in reusing. Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/#findComment-350542 Share on other sites More sharing options...
March 24, 201114 yr comment_350545 Blow-by,scored cylinder walls, low compression, poor gas milage. Never heard of a test performed after tear down. Link to comment https://www.classiczcars.com/forums/topic/38977-piston-rings/#findComment-350545 Share on other sites More sharing options...
