Posted March 28, 201114 yr comment_351085 Yep it blows out fog when started and driven. Plus new radiator is empty. SO up for sale or fix it. May be some stop leak but what Kind works?/ Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/ Share on other sites More sharing options...
March 28, 201114 yr comment_351093 or replace the gasket? Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/#findComment-351093 Share on other sites More sharing options...
March 28, 201114 yr comment_351095 Head gasket is a relatively easy job. I do mine in a casual weekend, or a hustle half day. Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/#findComment-351095 Share on other sites More sharing options...
March 28, 201114 yr comment_351100 Agreed. Head gasket is not a bad job. No way I'd sell a car just because of a bad head gasket. Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/#findComment-351100 Share on other sites More sharing options...
April 11, 201113 yr comment_352453 Agreed with the above opinions. If you've never done it before, or at least helped someone pull the head it can seem like a daunting task. Really, though, it's not that bad-assuming you take your time and have everything on hand before you start. Sure, there may be issues if your head is cracked or warped, but that might not be the case if this is a fairly new occurrence, or you've not driven it dry and hot...Of course another option for you is to pull the engine and replace it with a known to be good unit-surely you can find one somewhere. Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/#findComment-352453 Share on other sites More sharing options...
April 11, 201113 yr comment_352463 When our shop was down the road next to a wrecking yard, it would crack me up when someone would pull a rig out of the yard that had just shown up with some minor thing wrong.And I do mean minor easy fix stuff..... Put a head gasket in that thing. Easier than swapping a motor.... Also gives you a chance to check the bores.... Link to comment https://www.classiczcars.com/forums/topic/39050-think-i-got-a-blown-head-gaskettime-to-sell/#findComment-352463 Share on other sites More sharing options...
