Posted March 28, 201114 yr comment_351158 Hi, I was wondering what the best option would be? I currenntly have flattop carbs, but I was wondering if it really is worth getting them rebuilt by ztherapy. Otherwise the next cheapest solution is a new pair of weber dgv's, which I heard are not as good as su's, but I have only seen them compared to roundtops. I could get roundtops, but I have not been able to find the full setup, and then I would have to probably get those rebuilt. I have a 1973 240z with and L28, and I am on a very tight budget. Thank you for your help! Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/ Share on other sites More sharing options...
March 28, 201114 yr comment_351162 I don't think that Ztherapy will rebuild the flat top carburetors. They deal in the round tops, though Bruce could easily correct me on that point.I have a spare pair of flat tops that I plan on rebuilding. (Thank you 260 Z for your generous gift.) I figured it would be a great way to learn more about them. Rebuild kits are available. Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351162 Share on other sites More sharing options...
March 28, 201114 yr comment_351163 Yoshi, You will get a variety of opinions. There are a couple of options: 1. Learn to maintain the flattops. It can be done. Search HybridZ and zcar.com for TonyD. He has written about maintaining the Flattops and at one time had or has a standing offer to buy them. There is also a manual for the flattops. 2. If you can afford the Ztherapy Carbs I think that would be the general consensus. 3 Get a used set of the early SU's. Keep checking Ebay, the classified sections, post a parts wanted ad. Something will usually show up. Since I have no experience with Webers I can't help you. Dave Ruiz Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351163 Share on other sites More sharing options...
March 28, 201114 yr comment_351167 We are here to assist you in any way we can. For the flattop[ conversion we actually eat a third of the core charge. AND they are a bolt on. An early style aircleaner will be a bolt on as well as the flattop aircleaner has a different shaped opening to the carbs. Check out part number ZT161 or 162 depending how far into it you want to go...... Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351167 Share on other sites More sharing options...
March 28, 201114 yr Author comment_351175 I already have the flattop carbs, but I have no idea if they are rebuildable. How much would it cost to have them rebuilt then? Thank you all! Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351175 Share on other sites More sharing options...
March 28, 201114 yr comment_351177 Are you talking about getting the kits and doing them yourself? That's about $30 or so for the two kits. Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351177 Share on other sites More sharing options...
March 28, 201114 yr Author comment_351178 I have the kits, but I do not have any experience in rebuilding carbs, and I need my car running reliably asap. I would go to roundtops, but I am on a tight budget as a college student. And Bruce, are saying you can rebuild the flattops, even though I know they are not the best, or are you saying do the roundtop conversion? Thanks! Also, I am assuming new dgv's then are not the best option? Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351178 Share on other sites More sharing options...
March 28, 201114 yr comment_351184 We don't do them. Offered with out further comment..... Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351184 Share on other sites More sharing options...
March 28, 201114 yr comment_351186 I don't know of ANY commercial rebuilding service for flattops.New DGVs are an option, but I don't see much (if any) advantage to those over properly rebuilt roundtops. Plus, new DGVs aren't cheap. If your budget will cover new DGVs, you should also be able to swing a fresh set of roundtops (ZT161) at $730 (includes core). Edited March 28, 201114 yr by Arne Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351186 Share on other sites More sharing options...
March 28, 201114 yr comment_351187 A carb/manifold situation where the fuel mixture makes 90 degree turns,is always the last choice. Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351187 Share on other sites More sharing options...
March 28, 201114 yr comment_351205 These guys would probably rebuild them for you.http://www.paltech1.com/id2.htmlNot sure it's worth it and I have no idea what quality their work is.I got rid of my flat tops in the mid 80's... replaced them with webers... Then I replaced the webers with round tops in the late 90's. Now I'm happy Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351205 Share on other sites More sharing options...
March 29, 201114 yr Author comment_351224 I found the dgvs on sale which is why I should be able to afford them. So roundtop SU's are the best? I guess I'll just figure out how to rebuild my flattops until I have enough cash to get roundtops. Thanks for the help! Link to comment https://www.classiczcars.com/forums/topic/39060-flattop-carbs-rebuilt-or-new-dgvs/#findComment-351224 Share on other sites More sharing options...
