April 5, 201114 yr Author comment_352097 Yes there's a local yard that has 2 zx's and 1 z. No 240z but he says they have no been piced over much. I have not managed to stop by yet. Plan to this afternoon. Link to comment https://www.classiczcars.com/forums/topic/39136-will-a-5-speed-pay-for-itself/?&page=2#findComment-352097 Share on other sites More sharing options...
April 5, 201114 yr comment_352124 If your car has a newer 4 speed it might also have a different differential. You might check your rear gear ratio before you go, just so you know what you're working with.Plus, if you are still stock, that 3.36 ratio will be in an R180. The ZXz will probably be R200s if they are manual, which will be more work to swap in.And the 78 Z 5 speed most likely has the same first four gear ratios as your Type B 4 speed. Using it would give you the same ratios you have now, plus one more.There's a variety of combinations to choose from. Link to comment https://www.classiczcars.com/forums/topic/39136-will-a-5-speed-pay-for-itself/?&page=2#findComment-352124 Share on other sites More sharing options...
April 5, 201114 yr comment_352127 When you are at the yard, look for an '83 to '85 Nissan 4X4 truck. The front diffy will be a R180 with 3.9 or 4.11 gears. Some of the 200SX cars had R180 3.90 and 4.11 gears, too. If you want to use an R200 you will need a mustache bar out of a 280Z to do the swap.This link has some info on the Datsun/Nissan diffys:http://www.geocities.com/inlinestroker/ratio.html Link to comment https://www.classiczcars.com/forums/topic/39136-will-a-5-speed-pay-for-itself/?&page=2#findComment-352127 Share on other sites More sharing options...
April 5, 201114 yr Author comment_352140 I'll look. Thanks for tips. Have a bead on a 2.6 with 78 5 speed and 3 screw tops running and recently rebuilt for 450. Pulled for v6 t5 swap 3 years ago. Guy is clearing garage. Seems too good to be true. But worth risk I think. Link to comment https://www.classiczcars.com/forums/topic/39136-will-a-5-speed-pay-for-itself/?&page=2#findComment-352140 Share on other sites More sharing options...
