I had an apparently common problem (I've seen 2 or 3 threads about it) where the turn signals, brake lights, and gauges are all inop. I have had problems with the ignition switch (has to be just right" for the starter to engage:), so I took a chance that that was the issue...it was. If the switch is moved to the right (er, wrong) position I lose all the aforementioned functions. I just bought a used switch for a '72 on Ebay this evening, so a replacement is only a week away...it's working for now. I found several hillbilly wiring mods to the steering column that I will try to return to stock.
Later, guys...
