Posted April 5, 201114 yr comment_352137 Bruce Palmer, Z Therapy, made the comment on another thread about how effective the original airbox is on the Z, especially if you extend the air intake to the front of the radiator to draw in cooler air to both carbs. This made me rethink my current set up (K&N tuna cans) and put some thought to some plumbing ideas to make the original airbox arrangement more effective. Living in the desert heat makes me sensitive to improving the airflow to my SUs! Would those of you with customized cold air intake setups with the original airbox care to display your work? Any ideas on companies that provide the best setups? Open to any thoughts on this. Thanks! Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/ Share on other sites More sharing options...
April 6, 201114 yr comment_352170 I'm going to take the tube/corrigated hose that goes from the airbox to the exhaust manifold area (which preheats the air in the winter) and run it forward through the radiator support where there is already a hole. I happen to have a spare flange and funnel shaped piece from part of the exhaust system that will fit the hose perfectly. This will be bolted to the radiator support. This will allow cold air from the front, but utilize the stock filter. Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/#findComment-352170 Share on other sites More sharing options...
April 6, 201114 yr comment_352172 How about this? I have not used it, but it looks promising. http://shop.uniquezproducts.com/Cold-Air-Intake-Kit-Datsun-240z-260z-70-75-1300.htm Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/#findComment-352172 Share on other sites More sharing options...
April 6, 201114 yr comment_352173 Page 11 of the new NISSAN Sport $249 package from Unique Z Products. 619-808-5434 Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/#findComment-352173 Share on other sites More sharing options...
April 6, 201114 yr Author comment_352180 Thanks, guys, I thought after I posted this it may be a better question for Hybrid Z, but can always count on this great group for ideas!! I like that Unique Z Products package! Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/#findComment-352180 Share on other sites More sharing options...
April 22, 201114 yr comment_353573 Link to comment https://www.classiczcars.com/forums/topic/39142-su-cold-air-intake-options/#findComment-353573 Share on other sites More sharing options...
