Posted April 9, 201114 yr comment_352215 Does anyone know where I can get a heater control valve for my 78 280z 2+2? This is the one with a vacuum actuator on top. It is located under the dash against the firewall on the passenger side. Any help would be appreciated. Thanks PS. It has factory air. Edited April 12, 201114 yr by s14280zx Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/ Share on other sites More sharing options...
April 13, 201114 yr Author comment_352611 I am mainly concerned with having defrost and maybe heat so I can drive it without the windshield fogging up on inside. Is there any other parts I could swap from other z's that would give me defrost? Could someone explain how and when this valve opens and closes, and how it operates. Any info would help me greatly, and I would appreciate any advice. Thanks, Jeff. Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352611 Share on other sites More sharing options...
April 13, 201114 yr comment_352612 http://www.classiczcars.com/forums/showthread.php?38232-78-280z-heater-valve-needed!&highlight=heater+valve Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352612 Share on other sites More sharing options...
April 13, 201114 yr Author comment_352620 Thanks for the link, Steve. Greatly appreciated. Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352620 Share on other sites More sharing options...
April 13, 201114 yr comment_352622 palladin over on zcar.com figured out a rebuild procedure and wrote it up. It seems pretty popular, especially for those on low budgets.http://www.zcar.com/70-83_tech_discussion_forum/heater_valve_repair_895221.0.html Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352622 Share on other sites More sharing options...
April 13, 201114 yr comment_352647 Zed Head hit a solid Home Run finding this information on zcar.com. This has been a HUGE issue for a while!! I checked on the NAPA part and it was running $9.99 in Houston(as of the date of this post). I haven't checked the $$$ or availability of the Nissan Part, but will soon and repost here.My hat is off to Palladin over at ZCar.com for the hard work and writeup. Many thanks to both!!!BTW: the NAPA part number is: BK 6601000, Nissan Part Number: 27116-P6500 Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352647 Share on other sites More sharing options...
April 14, 201114 yr Author comment_352721 Great info guys, THANKS. Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-352721 Share on other sites More sharing options...
December 28, 201212 yr comment_410256 older post here has anyone tried the Nissan part on the older Z's? i ordered one today going to try to make it work in a 76.any info would be great. Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-410256 Share on other sites More sharing options...
September 16, 201311 yr comment_431784 kacrow: Did the NAPA repair item work for the heater control valve in your 76? Do you know whether it wpould work for a Series 1 Z? Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-431784 Share on other sites More sharing options...
September 16, 201311 yr comment_431794 yes i ordered the nissan part had to rework it a bit but it did work i took some pics i will see if i can find them. Link to comment https://www.classiczcars.com/forums/topic/39154-78-280z-22-heater-control-valve-leaking-coolant/#findComment-431794 Share on other sites More sharing options...
