Posted April 12, 201114 yr comment_352510 I removed the copper washer,ball and spring for the oil filter in preperation for the machine shop to hot tank block. Is this what you guys do or do most people leave these in the block?Brian Link to comment https://www.classiczcars.com/forums/topic/39200-engine-block-question/ Share on other sites More sharing options...
April 12, 201114 yr comment_352531 Removing the valve is a good idea, it allows the tank solution to circulate thoroughly.However, you should also remove the soft plugs from the front and rear faces of the block for the main oil gallery.Remove one plug by drilling through it, threading the hole and insert the appropriate bolt.Then lever under the bolt head with a flat lever, king size screwdriver etc.Protect the block with a scrap of wood.The plug will come out fairly easily.To remove the remaining plug I use a length of steel rod.Slip it into the open end of the gallery and tap the rod with the percussion device.Be careful not to spear the next door neighbor.The plugs and valve are cheap to replace, Nissan used zillions of them in all kinds of engines. Edited April 12, 201114 yr by Nissanman Link to comment https://www.classiczcars.com/forums/topic/39200-engine-block-question/#findComment-352531 Share on other sites More sharing options...
April 13, 201114 yr Author comment_352686 So I guess I can get that copper washer at the nissan dealership when I go to put it back in? Link to comment https://www.classiczcars.com/forums/topic/39200-engine-block-question/#findComment-352686 Share on other sites More sharing options...
April 14, 201114 yr comment_352747 Yes, I've never had any problems getting the soft plugs or the pressure relief valve. The valves I have seen and used are a self contained device with a spring loaded ball captive in it. You just slip the new valve into the hole in the oil filter boss in the block and gently tap it home. Yours is I gather something like this attachment, later versions are, as I say, a self contained device Link to comment https://www.classiczcars.com/forums/topic/39200-engine-block-question/#findComment-352747 Share on other sites More sharing options...
April 14, 201114 yr Author comment_352758 Thanks. Thats exactly what I have and needed to know. I'll try to get the self contained one.Brian Link to comment https://www.classiczcars.com/forums/topic/39200-engine-block-question/#findComment-352758 Share on other sites More sharing options...
