Posted April 13, 201114 yr comment_352630 Hi, so my starter died and I replaced it, but when I tried to start it, there was no clicking or anything. It sat for about a month until I had time to change the starter so is this most likely a problem of a dead battery? Is this right? Thanks! Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/ Share on other sites More sharing options...
April 13, 201114 yr comment_352632 First of all, what model, what year etc? Sounds like bad coil to me. Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352632 Share on other sites More sharing options...
April 13, 201114 yr comment_352634 Do the headlights still work. Does the horn work. If not, then more than likely you have a dead battery.:bulb: Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352634 Share on other sites More sharing options...
April 13, 201114 yr comment_352642 If you have power at the battery, bench test the starter to determine if the unit functions. Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352642 Share on other sites More sharing options...
April 13, 201114 yr Author comment_352677 Sorry, I have a 1973 240z, l28, re-manufactured gear reduction starter, and a slightly used msd blaster 2 coil. I'll definitely try the headlights an horns. As for the bench test, I will do that if the lights, etc. do work. Thanks for your help! Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352677 Share on other sites More sharing options...
April 14, 201114 yr comment_352733 Could also just be a bad connection at the battery, on either the ground or positive side. Clean the posts and clamps, be sure the battery is charged, and.... be sure you have the little yellow wire with the spade on it plugged in at the starter solenoid. It is the starter excite wire and the starter will NOT turn with out it. In fact, check there first........... Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352733 Share on other sites More sharing options...
April 14, 201114 yr comment_352772 Touch a small wire from the battery (+) terminal to the little spade connector on the starter's solenoid. If the starter springs to life, the problem is somewhere in your ignition switch wiring, and not in either the battery or starter. If so, it could be a bad fusible link. Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-352772 Share on other sites More sharing options...
April 20, 201114 yr Author comment_353355 I changed the battery, the lights go on now, but when I try to start it, it only clicks once which is like the starter is dead, but I just replaced it with a re-manufactured gear-reduction starter, any ideas? could this still be the fusible link? Or do I need to get the starter tested (which I really do not want to remove since I had to do it from the top which was a pain)? I will get the starter checked if I have to though, thanks! Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-353355 Share on other sites More sharing options...
April 20, 201114 yr comment_353356 Sounds like bad connection at the battery cables, on either post. Do the lights go out when it clicks? Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-353356 Share on other sites More sharing options...
April 20, 201114 yr comment_353357 Have you tried the test Sarah suggested? Make sure the car is NOT in gear when you do... Quote Touch a small wire from the battery (+) terminal to the little spade connector on the starter's solenoid. If the starter springs to life, the problem is somewhere in your ignition switch wiring, and not in either the battery or starter. Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-353357 Share on other sites More sharing options...
April 20, 201114 yr Author comment_353360 Alright, I need to get new battery cables anyway, and I'll try the test asap, can I just use any kind of wire? Thanks! Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-353360 Share on other sites More sharing options...
April 20, 201114 yr comment_353381 Yes, you can use any sort of wire. I suggest one with an alligator clip on the end. Be certain not to short to ground, or you will make a big (yet harmless) spark. Don't touch the wire to your bare fingers, or else the kick-back could give you a bit of a shock.And YES, by all means be absolutely certain the car is out of gear, or else you could end up with a wheel ontop of your foot! Yikes! (Good catch, Kenny!)Is the clicking definitely from the starter and not a relay? If so, that's all the involvement any of your fusible links would have. If the solenoid clicks, and the supply is good to the starter via the fat battery cables (both the positive from the battery's (+) to the starter's (+) and the negative from the battery's (-) to the engine ground), then the starter should spring to life. Two possibilities are that your cables are bad or that your battery is bad. Your cables might have severe corrosion near the battery post connectors, just underneath the insulation. If so, you might see a bulge there. Also check to see that your connections are firm.If your cables are in good shape and making good contact, you can determine the integrity of your battery by turning your headlights on and turning the key to "start." If your headlights glow dimly before you turn the key and go completely out when you turn it, your battery is weak/bad. If your headlights glow pretty well whether you turn the key or not, and if your starter definitely clicks, then the starter is probably bad.FAIW, you can pull both your starter and your battery off and take them in for testing at many/most parts stores. I think I would trust a starter test, but these stores are notorious for misdiagnosing batteries, so take their results with a grain of salt. Edited April 20, 201114 yr by FastWoman Link to comment https://www.classiczcars.com/forums/topic/39212-new-starter-no-cranking/#findComment-353381 Share on other sites More sharing options...
