Posted April 13, 201113 yr comment_352666 I am guessing there is a lot of resistance in the connection. I was driving with the wipers on and the steering column started puffing some smoke. I turned them off, but the smell stayed around for a while.So am I at the point of removal, cleaning and maybe some solder?Is this the the same type of problem with the fuse box?Thanks!W Link to comment https://www.classiczcars.com/forums/topic/39216-wiper-switch-causing-smoke/ Share on other sites More sharing options...
April 13, 201113 yr comment_352676 Yes, clean all electrical connections of corrosion and it should be an improvement. Link to comment https://www.classiczcars.com/forums/topic/39216-wiper-switch-causing-smoke/#findComment-352676 Share on other sites More sharing options...
