Email logins are now active ×
rod bearing replacement with engine still in the car?
spdcrazy
i need to search further to make sure it is a rod bearing, but i have a rattle in the engine from about 2300 rpm to 3300rpm's. if so, i should be able to pull a spark plug wire one at a time and single out the cylinder/s that need new bearings ya? then can they be replaced with the engine in the car? just drop the oil pan and replace?
