Identifying the year of your car will go a long way towards getting a meaninful answer. Put your Year info in your signature block via your User Panel.
Thankfully, for the majority of the Z's, they're plastic rivets with a pin spreader. Push the pin through the rivet (and retrieve it if possible), and then carefully pull the rivet up and out. Take care on the bottom edge of the finisher as it's held to the body with a sheet metal grip that's unobtainium. You should be able to just pull it out of it's teeth, don't use anything to spread it's jaws.
FWIW
E
Ben,
Here is a link to the thread I used when I refurbished mine:
http://www.classiczcars.com/forums/showthread.php?13593-Color-for-grill-rear-tail-light-panel&p=90742&viewfull=1#post90742.
Your company sells fasteners that are almost exact replacements. Just follow EScanlon's instructions for removal.
I repaired cracks and such with JB Weld and sanded prior to painting. I have spares if needed.
