Fog lights
Pomorza
Beams may drop down at high speed, as I assume the front lip spoiler will flex a little under load. Not a problem for me since I don't drive fast at night...
Of course, it would be easy to install some support brackets from the frame rail to prevent this from happening.
Oiluj, what brand are those lights, I'm looking for a set to mount in the same spot?
Got them at Autozoneo about a year ag. They were inexpensive, "Blazer" brand halogen driving lights.
They do a decent job of improving visibility at normal, (non-autobon), freeway speeds and I'm happy with appearance.
I did have to modify the backets to make them fit in the barke ducts.
  • 3 months later...
Actually, those are meant to be brake cooling ducts, but I found lights that would fit...
Most peole I've talked to, insist the holes are specifically FOR the lights, and the brakes don't need cooling.
Edited by TomoHawk
