Posted April 15, 201113 yr comment_352839 Does anyone know if a 1983 turbo manifold will fit a 1981 n/a motor? Link to comment https://www.classiczcars.com/forums/topic/39242-i-could-use-some-help/ Share on other sites More sharing options...
April 15, 201113 yr comment_352865 Yes (and yes).Both the intake and exhaust manifolds will bolt up to the N/A head.What's more important is that if you add a turbocharger is that you get the turbo head and cam.Then there is the ignition control, etc, etc, Link to comment https://www.classiczcars.com/forums/topic/39242-i-could-use-some-help/#findComment-352865 Share on other sites More sharing options...
