Posted April 15, 201113 yr comment_352888 Does anyone here know if the lower radiator support member is available after market? This is spot welded in and makes up the front cross member that completes the "box" at the front end.Thanks for any input. Link to comment https://www.classiczcars.com/forums/topic/39250-lower-radiator-support/ Share on other sites More sharing options...
April 15, 201113 yr comment_352901 You are welcome to the one on my parts car. It is a '78 (and it is in Houston). Link to comment https://www.classiczcars.com/forums/topic/39250-lower-radiator-support/#findComment-352901 Share on other sites More sharing options...
April 17, 201113 yr Author comment_353084 Andrew, thanks for the offer. At the MSA show yesterday I realized that the 280 supports are different from the 240's. I'll have to keep hunting. Link to comment https://www.classiczcars.com/forums/topic/39250-lower-radiator-support/#findComment-353084 Share on other sites More sharing options...
April 20, 201113 yr comment_353363 Hey zcurves, any chance you could cut it out if I purchase it? If so, how much would you want? Link to comment https://www.classiczcars.com/forums/topic/39250-lower-radiator-support/#findComment-353363 Share on other sites More sharing options...
