Posted April 16, 201114 yr comment_352937 Ok I disconnected my engine mounts to lift the motor to replace the oil pan gasket. now the job is done and i can't get the mounts to align, the engine is sitting about a half inch back from where its supposed to be. Link to comment https://www.classiczcars.com/forums/topic/39260-motor-mounts-wont-align/ Share on other sites More sharing options...
April 16, 201114 yr comment_352956 If you have a hoist you should be able to lift the engine slightly and pull it forward. How did you lift the motor in the first place? Link to comment https://www.classiczcars.com/forums/topic/39260-motor-mounts-wont-align/#findComment-352956 Share on other sites More sharing options...
