Posted April 17, 201114 yr comment_353126 In the book that came with the car it said the adjustment nut was 15mm, and I saw that somewhere else, however my adjustment nut was 14mm. However the other nut I loosened was 17mm. Was something changed on my car in the past do you think?As far as the adjustment goes most of the exhaust valves were too tight. I believe it said .012 in the manual. I made sure that when done that .014 and .010 would not fit. On the intake valves I made sure .006 and .010 would not fit after I felt a slight drag on .008 I hope all it well. This was cold and I have not put on the valve cover as I am wet sanding the valve cover to polish it later today. Link to comment https://www.classiczcars.com/forums/topic/39275-adjusted-my-valves-14mm-not-15mm-wrench-used/ Share on other sites More sharing options...
April 20, 201114 yr comment_353461 14mm/17mm is correct.I prefer single blade feeler gauges in single increments (others like the stepped blades)Hot intake= .009 loose/ .010 drag/ .011 won't go exhaust= .011 loose/ .012 drag/ .013 won't goCold:Intake .008Exhaust .010Hot:Intake .010Exhaust .012 Link to comment https://www.classiczcars.com/forums/topic/39275-adjusted-my-valves-14mm-not-15mm-wrench-used/#findComment-353461 Share on other sites More sharing options...
April 21, 201114 yr comment_353515 Willoughby Z is correct, Ben. Link to comment https://www.classiczcars.com/forums/topic/39275-adjusted-my-valves-14mm-not-15mm-wrench-used/#findComment-353515 Share on other sites More sharing options...
