Hey guys,
I replaced Input, Output, and front cover seals today. Planning on putting into car tomarrow, can't wait to be able to shift into 5th. Swapped Automatic to 4 speed 3-4 years ago, unable to find a 5 speed at that time. It feels like I just did this, shouldn't take too long.:D
Bryce
https://www.classiczcars.com/forums/topic/39302-4-speed-to-5-speed-swap/
Hey Kenny,
As of right now I have a 3.54 original diff. in it. Just cracked open the extra diff. yesterday to check the numbers stamped in the gear. Luckily it's a 3.90, I was hoping it wasn't the same as I had in it. I will start getting it ready to go in after I get the 5 speed in today. Is there anything I need to know when putting the 3.90 in? Do I need to find any other parts, or does it just swap directly over with my 3.54? Thanx for any info.
Bryce
Hi Bryce, if it is a 3.90 R180 from a Nissan 4X4 truck it is an easy swap. Simply unbolt the flanges from both diffys, then install the 3.54 flanges onto the 3.90 diffy. The attached photo shows the difference between the flanges, the one to use is on the right in the photo. If the 3.90 is an R200 you will need a mustache bar from a 280Z. Search the site and you should find some info on installing a R200.
Bryce,
For the speedometer to be correct, you'll also need the speedometer pinion gear. They are different colors depending upon which diff you have. I think I got mine at zspecialties. This has nothing to do with the function of the tranny, just the accuracy of the speedo.
Update,
I installed the 5 speed and just got done driving it. Should feel nice on the highway, and be a little less loud.
tlorber, thanks for the heads up. I have the z performace mods website saved in my bookmarks, but didn't know where to go about finding the White 19 tooth gear. Thanx
Bryce
Recently Browsing 0
