Posted April 22, 201114 yr comment_353633 Car keeps overheating on warm days (60+ degrees). It has the three speed auto so naturally it runs at 3600rpms going 70mph. It won't heat up if I stay at 55mph, but as soon as I speed up, it will over heat to 240-260 degrees. So:I suspected a stuck t-stat. Checked, t-stat was removed by previous owner.So what now? New water pump? The car has 80k original miles on the engine, so I am guessing it could be getting old and gunked up. Any other ideas?Oh yes, and should I reinstall the new t-stat I got, or leave it deleted? Edited April 22, 201114 yr by ZohanIsBack Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/ Share on other sites More sharing options...
April 22, 201114 yr comment_353635 you need the stat for propeer temp management, reinstall. Flush the cooling system. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353635 Share on other sites More sharing options...
April 22, 201114 yr Author comment_353636 Great. Thanks! Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353636 Share on other sites More sharing options...
April 22, 201114 yr comment_353642 I would send the radiator out to be cleaned. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353642 Share on other sites More sharing options...
April 22, 201114 yr comment_353645 If you are getting that much of a temp extreme, I would pull the radiator and have it rodded out, boiled, pressure tested, and definitely install the correct thermostat. Restricted flow in the radiiator core will definitely defeat the purpose of the cooling system. before taking it out, though, being very conservative, I would also put a chemical flush through the whole system to make sure there is not a large sediment buildup in the block which may not allow efficient heat transfer to the cooling medium. Not that expensive to do if removing and installing components yourself. Dan Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353645 Share on other sites More sharing options...
April 22, 201114 yr Author comment_353646 It's doesn't look too bad through the top--that's not saying a whole lot though. I'll run some firestone radiator flush through it first. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353646 Share on other sites More sharing options...
April 22, 201114 yr comment_353678 Another vote for pulling the radiator and dropping it at a shop for rodding out and cleaning. Also put in a 180 thermostat. That's not your problem, but you need one. Finally, it's unlikely a bad water pump would be your problem. The vanes would have had to rust away, which would be unlikely.Prestone radiator flush does little or nothing to help a corroded radiator. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353678 Share on other sites More sharing options...
April 23, 201114 yr Author comment_353696 Well, I already had a bottle of the super strength stuff for neglected radiators so I figure it's worth a shot to see how it works. As far as taking it into the shop goes, does anyone know how much that runs? It's $80 for a new one, so.....there's a lot at stake here. I do appreciate all your input though! I did get a 180 t-stat. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353696 Share on other sites More sharing options...
April 23, 201114 yr comment_353741 Flush the system BEFORE doing anything with the radiator. If there is a buttload of slop in the block the flush may clog parts of the new/ referbed core. Just my opinion. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-353741 Share on other sites More sharing options...
April 26, 201114 yr Author comment_354083 Agreed, well....I'm putting in the new t-stat today, so we'll see if it works. Had to tap new bolt holes though....The stupid previous owners stripped the threads and glued the bolts for the t-stat upper unit in place. Idiots... Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-354083 Share on other sites More sharing options...
April 26, 201114 yr comment_354096 Are you saying that its $80.00 for a new radiator? That sounds very cheap. MSA sells them for around $275.00 and I recently bought a 3 row (the same one they sell) for around $225.00. You might check to see how many rows yours has. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-354096 Share on other sites More sharing options...
April 26, 201114 yr Author comment_354102 It was, but yeah, I have no idea as far as quality is concerned. Link to comment https://www.classiczcars.com/forums/topic/39333-cooling-problemhelp/#findComment-354102 Share on other sites More sharing options...
