Posted April 23, 201114 yr comment_353752 My 77 has just developed difficulty shiting into gears. (5 speed) It is classic signs of a failing slave cylinder except no leakage anywhere. The master is still full.Questions:Is this a simple pedal adjustment? If so, adjust closer to floor?Could the fluid be too old and broken down? Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/ Share on other sites More sharing options...
April 23, 201114 yr comment_353753 Clutch cylinders (especially the master, but also the slave) can leak past the seal internally - no external leaks seen. I would probably replace both master and slave as a pair. (I've never had success replacing only one or the other, the old one always fails shortly after replacing the first.) I'm betting this will fix your problem. Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/#findComment-353753 Share on other sites More sharing options...
April 23, 201114 yr Author comment_353758 Arne, you're probably right. What about the fluid level still being full? Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/#findComment-353758 Share on other sites More sharing options...
April 23, 201114 yr Author comment_353759 One other note. The slave cylinder can be easily depressed by hand. Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/#findComment-353759 Share on other sites More sharing options...
April 23, 201114 yr comment_353765 n2deep said: Arne, you're probably right. What about the fluid level still being full?Internal by-passing in the master cylinder will not affect the fluid level. It will stay full. What is probably happening is that the master cylinder piston seals are leaking, and so not enough fluid is being pushed to the slave. Edited April 24, 201114 yr by Arne typo fix Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/#findComment-353765 Share on other sites More sharing options...
April 23, 201114 yr Author comment_353768 That makes sense. Thanks. Link to comment https://www.classiczcars.com/forums/topic/39345-clutch-adjust-or-slave-cylinder/#findComment-353768 Share on other sites More sharing options...
