  • 1 month later...
A little follow up on this thread, i ordered this BPT and it does not fit my 77 280z. This one has a solid nipple that looks like a hose attaches to it, mine has a threaded boss that attaches to a steel line that comes from intake manifold below the EGR Valve.
https://www.classiczcars.com/forums/topic/39351-bpt-valve/#findComment-359727
I believe the steel line that comes up from the intake manifold is similar on the 78, however it's cut off and there is only a vacuum hose connecting the steel line to the BPT. You might simply cut the boss off with a pipe cutter, and connect via vacuum line. An idea anyhow..
https://www.classiczcars.com/forums/topic/39351-bpt-valve/#findComment-359728
