Posted December 16, 200222 yr comment_20996 I'm a relatively newbie to cars and i happend to get a 240Z for my first car....i've had it for one summer well half of it, it's parked now fo the winter...i've got some 195/60R 14 85H Ok now i have NO idea of what these numbers mean...can anyone help me with that? They are the yokohama or something along those lines in the brand name.. They are pretty old, and cracked, and the front i found has a really slow leak. and they suck at getting grip of the line. So can someone tellme what the numbers mean? And what kind of tires i should get for the best performance? Steering, getting grip.... anyways thanks alot. Link to comment https://www.classiczcars.com/forums/topic/3937-new-be-needs-help-on-tire-size/ Share on other sites More sharing options...
December 16, 200222 yr comment_20997 the first number 195 is tire width60 is the aspect ratio hiegth from side wall to the top of the tireand the last number is the wheel diameter Link to comment https://www.classiczcars.com/forums/topic/3937-new-be-needs-help-on-tire-size/#findComment-20997 Share on other sites More sharing options...
December 16, 200222 yr comment_21000 you can find some decent info at www.tirerack.com Also try searching for previous posts about tires here to find out more. FWIW, most i know choose 205/60/14 (if running 14 inch rims still). Good luck! Link to comment https://www.classiczcars.com/forums/topic/3937-new-be-needs-help-on-tire-size/#findComment-21000 Share on other sites More sharing options...
