Posted May 3, 201113 yr comment_354663 Moved the server to a new IP today. DNS should only take an hour for most people, but, some remote locations can take up to 48 hours. Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/ Share on other sites More sharing options...
May 3, 201113 yr comment_354675 Thanks, Mike.jlp Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354675 Share on other sites More sharing options...
May 3, 201113 yr comment_354692 The new sever seems hyper-slow? Here is a test to verify:ping zcar.comPinging zcar.com [208.43.51.5] with 32 bytes of data:Ping statistics for 208.43.51.5: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 70ms, Maximum = 155ms, Average = 116msping classiczcars.comPinging classiczcars.com [173.164.116.65] with 32 bytes of data:Ping statistics for 173.164.116.65: Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),Approximate round trip times in milli-seconds: Minimum = 143ms, Maximum = 375ms, Average = 226msC:\Users\Owner> Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354692 Share on other sites More sharing options...
May 3, 201113 yr comment_354693 ping zcar.comPing statistics for 208.43.51.5: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 68ms, Maximum = 69ms, Average = 68msping classiczcars.comPing statistics for 173.164.116.65: Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),Approximate round trip times in milli-seconds: Minimum = 135ms, Maximum = 137ms, Average = 135ms Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354693 Share on other sites More sharing options...
May 3, 201113 yr Author comment_354699 Hmm, it shouldn't be slow. The new service plan is 50Mbps download and 10Mbps upload. The upload value is what all users should see on the site. I'll have to check into this. I wonder if there's a speed tester for command line Linux? Do you know of any tools to do this?m Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354699 Share on other sites More sharing options...
May 3, 201113 yr Author comment_354704 Just checked with the ISP and there's nothing physically causing this link to be slow. Speed tests indicate that we should be seeing speeds in excess of 11Mbps from the server to end users. I'm wondering if there's something on the server causing this such as link speed or firewall issue. Looking into it now. Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354704 Share on other sites More sharing options...
May 3, 201113 yr comment_354708 might want to turn off some things in Vbulletin to see if they make a difference, my site is small and on a shared server, but the blog and CMS really slowed things down Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354708 Share on other sites More sharing options...
May 3, 201113 yr comment_354709 could be routing. I did a trace route and the path was halifax-nyc-dc-atlanta-dallas-la-oregon.Here are some linux commands: http://linux.about.com/od/commands/l/blcmdl8_ping.htmhttp://linux.about.com/library/cmd/blcmdl8_traceroute.htmbtw this is my second attempt at replying as my first attempt timed out Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354709 Share on other sites More sharing options...
May 6, 201113 yr Author comment_354937 We found some interesting things today with the IP addresses after the move. I removed some extra IP's associated with the Eth0 card and restarted the server. This may make an improvement on the packet loss.However, I also noticed that our newest software changes has been showing more CPU use than with our previous software. I've got plans to move the server to a new more powerful machine this month. The new machine has got two processors (dual core) and twice as much memory. The HDD's are in a RAID5 configuration which should also improve performance. These changes alone should make the system much more efficient.I also did some digging into our new ISP and it looks like we are seeing well above the rates that were purchased. Getting 60Mbps downloads and 15Mbps uploads and we are paying for 50/10. So, the network side looks like it's working just fine.I'm going to save too much digging on this until we are able to put the new server in place. From what I can see, a hardware improvement will make this place much more efficient. At least until the next upgrade. HA.m Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354937 Share on other sites More sharing options...
May 6, 201113 yr comment_354951 Thanks for the diligent work and upgrades! Unfortunately I am still getting packet drops. The path seems fine up to Dallas however once it goes into comcast's west coast network it falls apart.Pinging classiczcars.com [173.164.116.65] with 32 bytes of data:Reply from 173.164.116.65: bytes=32 time=141ms TTL=46Reply from 173.164.116.65: bytes=32 time=142ms TTL=46Reply from 173.164.116.65: bytes=32 time=141ms TTL=46Request timed out.Ping statistics for 173.164.116.65: Packets: Sent = 4, Received = 3, Lost = 1 (25% loss),Approximate round trip times in milli-seconds: Minimum = 141ms, Maximum = 142ms, Average = 141msPinging zcar.com [208.43.51.5] with 32 bytes of data:Reply from 208.43.51.5: bytes=32 time=69ms TTL=54Reply from 208.43.51.5: bytes=32 time=69ms TTL=54Reply from 208.43.51.5: bytes=32 time=70ms TTL=55Reply from 208.43.51.5: bytes=32 time=69ms TTL=54Ping statistics for 208.43.51.5: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),Approximate round trip times in milli-seconds: Minimum = 69ms, Maximum = 70ms, Average = 69msTracing route to classiczcars.com [173.164.116.65]over a maximum of 30 hops: 1 5 ms 4 ms 5 ms 192.168.0.1 2 16 ms 15 ms 16 ms loop0.87w.ba15.hlfx.ns.aliant.net [142.176.50.14] 3 15 ms 29 ms 15 ms te-0-0-0-0-83.cr01.hlfx.ns.aliant.net [142.176.53.34] 4 15 ms 15 ms 17 ms xe-8-2-1.cr02.hlfx.ns.aliant.net [142.166.185.66] 5 15 ms 15 ms 16 ms xe-2-0-0.cr02.drmo.ns.aliant.net [142.166.185.74] 6 37 ms 37 ms 38 ms xe-0-0-0.bx01.toro.on.aliant.net [207.231.227.86] 7 38 ms 38 ms 53 ms 67.69.211.21 8 52 ms 74 ms 60 ms BX4-CHICAGODT_POS12-0.net.bell.ca [64.230.186.238] 9 53 ms 73 ms 54 ms be-10-407-pe01.350ecermak.il.ibone.comcast.net [75.149.231.37] 10 55 ms 55 ms 54 ms pos-0-3-0-0-cr01.chicago.il.ibone.comcast.net [68.86.87.249] 11 65 ms 63 ms 63 ms pos-2-14-0-0-cr01.atlanta.ga.ibone.comcast.net [68.86.85.170] 12 85 ms 85 ms 86 ms pos-1-10-0-0-cr01.dallas.tx.ibone.comcast.net [68.86.86.129] 13 * 130 ms 136 ms pos-0-13-0-0-cr01.losangeles.ca.ibone.comcast.net [68.86.85.145] 14 124 ms 125 ms * pos-0-15-0-0-cr01.sacramento.ca.ibone.comcast.net [68.86.85.85] 15 136 ms 138 ms 136 ms so-1-0-0-0-ar03.beaverton.or.bverton.comcast.net [68.86.95.110] 16 160 ms * 137 ms po-10-ar01.beaverton.or.bverton.comcast.net [68.87.218.165] 17 * 140 ms 139 ms te-8-2-ur01.eugene.or.bverton.comcast.net [68.87.218.210] 18 * 137 ms 136 ms ge-3-1-0-ten02.eugene.or.bverton.comcast.net [68.85.148.118] 19 150 ms * TOSHIBA [192.168.0.105] reports: Destination host unreachable.Trace complete. Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354951 Share on other sites More sharing options...
May 6, 201113 yr Author comment_354967 Hi Blue, it looks like you are just farther away (in hops) from our server. Your route seems to jump across the entire USA before it even gets to us. It doesn't appear that changes to our server will improve your speed. I'll raise the issue with Comcast to see if they have any answers about this. Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354967 Share on other sites More sharing options...
May 6, 201113 yr comment_354972 Thanks! Yup I am nearly as far east as you can go but the poor folks in Australia, Japan, SA, Europe, etc have it worse.The packet loss seems to occur a lot when pinging. I just tried again and only got 2 replies from 4 sends. Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354972 Share on other sites More sharing options...
May 6, 201113 yr comment_354977 just for reference I am in south floridaPing 173.164.116.65[classiczcars.com]Round trip time to 173.164.116.65: 69 msRound trip time to 173.164.116.65: 69 msRound trip time to 173.164.116.65: 69 msRound trip time to 173.164.116.65: 69 msRound trip time to 173.164.116.65: 70 msRound trip time to 173.164.116.65: 67 msRound trip time to 173.164.116.65: 69 msRound trip time to 173.164.116.65: 67 msRound trip time to 173.164.116.65: 67 msRound trip time to 173.164.116.65: 68 msAverage time over 10 pings: 68.4 msTraceRoute to 173.164.116.65 [classiczcars.com]Hop (ms) (ms) (ms) IP Address Host name1 1 0 0 206.123.64.154 - 2 0 0 0 64.124.196.225 xe-4-2-0.er2.dfw2.us.above.net 3 0 0 0 64.125.26.205 xe-0-0-0.er1.dfw2.us.above.net 4 1 0 0 64.125.13.186 above-comcast.dfw2.us.above.net 5 0 0 0 68.86.86.89 pos-2-0-0-0-cr01.dallas.tx.ibone.comcast.net 6 34 34 34 68.86.86.217 pos-0-10-0-0-cr01.losangeles.ca.ibone.comcast.net 7 44 45 44 68.86.86.1 pos-0-13-0-0-cr01.sacramento.ca.ibone.comcast.net 8 57 57 57 68.86.95.118 so-6-0-0-0-ar03.beaverton.or.bverton.comcast.net 9 57 58 57 68.87.218.165 po-10-ar01.beaverton.or.bverton.comcast.net 10 61 61 61 68.87.218.210 te-8-2-ur01.eugene.or.bverton.comcast.net 11 55 55 55 68.85.148.118 ge-3-1-0-ten02.eugene.or.bverton.comcast.net 12 60 61 61 96.132.221.202 - 13 67 67 67 173.164.116.65 173-164-116-65-oregon.hfc.comcastbusiness.net Trace complete Link to comment https://www.classiczcars.com/forums/topic/39446-server-ip-change/#findComment-354977 Share on other sites More sharing options...
https://www.classiczcars.com/forums/topic/39446-server-ip-change/Share on other sites
