Posted May 3, 201113 yr comment_354700 im looking for springs that handle good in street and some performence. my 78 280z right now has about 4 inches from tire to fender on back and almost six in front. have tokico shocks infront and replaced back with monroe. i want the ride to be a little stiffer, what brand are good without killing my wallet. this are temparery till i save enough to go all adjustable. Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/ Share on other sites More sharing options...
May 3, 201113 yr comment_354718 MSA has their the Eibach lowering springs for sale until the end of today I believe. $179 if I remember correctly. I don't have personal experience with them yet but from what I've read they are a nice set for the street. Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-354718 Share on other sites More sharing options...
May 4, 201113 yr comment_354729 I too am looking at springs to run with KYB struts. Does anyone else run these with KYB's? Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-354729 Share on other sites More sharing options...
May 4, 201113 yr comment_354741 Just last week installed a set of Eibachs and Tokicos on my 240 and I like them. The car handles well and the ride is very good IMHO. Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-354741 Share on other sites More sharing options...
May 4, 201113 yr comment_354755 I too am looking at springs to run with KYB struts. Does anyone else run these with KYB's? I've had Eibachs with KYBs on my 73 240Z for over a year now. Probably have put 2000 miles on them. So far' date=' so good, despite KYB's warnings not to use them with lowering springs. Other users here report similar success. I like how they ride, too. You end up with about 5 .5 inches of ground clearance when measured from the low spot in the frame rails right in front of the rear tire. See attached pictures. Notice the molded plastic mud flaps. The rear ones are gone now, as they wouldn't clear speed bumps. The front ones are fine, and I've left them on, as they do help prevent rock chips. One nice thing about the Eibachs is that you barely need a spring compressor to get them on. Easy to install. If I remember right, either the fronts or backs could be compressed enough by hand to get the nut on the strut assembly. Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-354755 Share on other sites More sharing options...
May 8, 201113 yr comment_355098 I ran eibach springs and tokico hp shocks on a 76 2+2 and really liked the look and performance. Had to run the 240 or 280 front isolator bushings in the back also to level the car out. I dont know how to post pics on here but will be more than happy to email you a few if you need Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-355098 Share on other sites More sharing options...
May 8, 201113 yr comment_355099 This might work for the pics Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-355099 Share on other sites More sharing options...
May 8, 201113 yr comment_355100 And one more Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-355100 Share on other sites More sharing options...
May 8, 201113 yr Author comment_355151 The pictures help slot thanx. I think I'm going with eibach.My car is a 280z 2+2 do you think I need the isolator bushing in the back Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-355151 Share on other sites More sharing options...
May 8, 201113 yr Author comment_355154 After I find out how to post pics I'll post the picture of the car and the it's height Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-355154 Share on other sites More sharing options...
June 21, 201113 yr comment_359369 You dont need the isolators but it will be stink bugging with the back a bit higher than the front. I am running 16x7 +4 rota rb with 245-50-16s. Eibach springs, Tokigo struts and then put the shorter isolators in the back to level it out. From my understanding Nissan had to put 3/4" taller isolators in the back to get the bumper up to legal height. So grab any 2 240 isolators or 2 front 280's and stick them in the back and it will come out level. Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-359369 Share on other sites More sharing options...
June 21, 201113 yr comment_359370 PS the ride with that set up is comfortable but firm. I am extremly happy with it. The steering is a bit heavy at low speeds due to the 245s but other than that I am happy withe the combination Link to comment https://www.classiczcars.com/forums/topic/39452-need-lowering-springs-ideas/#findComment-359370 Share on other sites More sharing options...
