My temp gauge has been erratic, so I bought a coolant temp sensor. Beck Arnley Part# 158-0134. Rock Auto confirms this is correct sensor... http://www.rockauto.com/catalog/raframecatalog.php
There are three somethings threaded into the thermostat housing. The Beck Arnley part is 18mm, I took one out that was 23mm, the female plug end on the new sensor wasn't right. The other sensor that is in there I didn't bother to remove because the plug on that was not going to work with the new sensor either.
Am I looking in the wrong spot? Is the cataloging wrong? What three things are tapped in to the thermostat housing?
https://www.classiczcars.com/forums/topic/39478-coolant-temperature-sensor/
that is one of the temp sensors. there are 3 (ish) the thermotine switch, and 2 sensors. one sensor feeds data to the computer (this is the one you have, 2 connector plug) then one runs the temperature gauge on the dash, that is only one bullet connector
AIRTEX / WELLS Part # 1T1181 is the better choice because it has the threads built in, or STANDARD MOTOR PRODUCTS Part # TS69
http://www.rockauto.com/catalog/moreinfo.php?pk=935425
hope this helps.
I have 2, 2 connector plugs. Funny part is this beck arnley part wouldn't plug in to any of them.
hope this helps.
Well I took off the one bullet connector and much to my surprise there was corrosion all over the male end of the connector. I took a scotchbrite pad, scuffed it and used electrical contact cleaner on the sensor and harness and now my gauge reads very accurately.
