Big problem or little problem???
New_BE
Hello peoples...well i noticed a half inch thick stip of rust along the top of the windshield, where it seals...how's the best way to fix this so it looks good? My dad says to use a black sealent, but my car is red, my dad is a fix-it kineda person...however i want it to look good and am thinkin maybe a paint job depending on how much stuff will need to be fixed with it....like the rust which isn't visible and needs to be fixed befroe hand...anyone help on how to look for these kinda of spots? thanks alot u guys/gals are very helpfull
You should investigate as to whether or not the rust is coming from under the windshield gasket. If it is, you really should take out the windshield and fix it corrrectly, otherwise it will only come back and the damage will be even worse and the cost will go up accordingly.
Lets see, where to look for rust on the Z car.....
1. Under the battery tray,
2. inner fender wells behind the brake lines,
3. lip where the frame rail meets the inner fender well,
4. lower portion of the rad support,
5. floors,
6. inside the engine comapartment where the inner fender well attaches to the frame rail
7. toe boards
8. rockers
9. Rear lip where the hatch meets back end of the car
10. wheel arches
11. inner rockers
12. entire floor inside the car UNDERNEATH the carpet
13. firewall
14. Support rail underneath the fender
15. inside the cowl
16. bottoms of the doors
17. top of the windshield (this one is actually common)
18. rear quarters
19. Rear panel (under the bumper)
20. headlight bucket mounts
take yourself out a measuring tape. go inside the engine compartment and measure 6 inches up from the bottom of the frame rail....that six inches worth of metal all the way around the entire vehicle is prone to rust.
you need to get the car up on jackstands, remove the wheels, get a flashlight and a screwdriver.....and start poking and prodding. Rust hides underneath the undercoating and an area that looks solid may just surprise you as the screwdriver pokes through.
Alright thanks alot..i do have a magazine from way back when the car was new and in sport mags and such..i got them along with the car, and they tell ya the places prone to rust...i was curious...if i did have a rust hole through the grame rail in the engine bay area, what does it take to fix this? I saw another Z and the guy was selin it however the frame rail had a hole about an inch by two in it. Woudl u need to cut this out and weld another piece the same size back in? i didn't really check the engine bay verywell... so if i do have this i hope it's not too much trouble ot fix..i also fixed the holes in the floor however i'm gonnna get new ones this spring... How do i go about fixint the rust on the roof if it is how too many Z's said it might be? thanks alot guys/gals
I love this car
