Of course, the '76 we are working on has cracked boots, and in the case of the air regulator, a broken connector. My first question is are there any tricks to cleaning the connectors? the air regulator plug is definitey corroded, I'm sure there are others that are as well. My second question is, what is the best replacement conntector to use, and where should I get them? I want to solder/shrink tube whatever I use, I won't be using butt connectors in a fuel injection harness.
