Posted May 8, 201113 yr comment_355156 Have the MSA rear sway bar, looking to install in my 70 240Z with 83 ZX 5 speed and R200 diff, with the Arizona Z mustache bar. Has not had rear sway bar before and I don't have instructions about mounting correctly. Looked through prior posts but didn't see anything about installing with my circumstances. Any written instructions with diagrams out there that someone could send me? Will contact MSA Monday, but figured someone has done this before and knows the best way to do this. Thoughts?Thanks! Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/ Share on other sites More sharing options...
May 8, 201113 yr comment_355170 I think there should be U clamps that mount on the rear differential hangers that hold it on an early Z. Like this Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-355170 Share on other sites More sharing options...
June 23, 201113 yr comment_359590 Blue said: I think there should be U clamps that mount on the rear differential hangers that hold it on an early Z. Like this Yes, you have to have the "replacement" hanger pieces that have the addition material out to the sides that the swaybar attaches to. The ADCO bar I used came with those hanger plates (1973 year of our Lord) Don't know if you got those with your bar but you must have. Later model Z's that came with the factory rear bar had an attachment point on the floor pan. A reinforced area, and captured nut where the bar was attached to the body. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-359590 Share on other sites More sharing options...
July 1, 201113 yr comment_360290 Steven,I have one installed in my 71 but it looks like mounts have been fabricated to attach to the floor pan. I also have another rear sway bar I'd like to install on my 72 so let me know what you learn about the brackets and mounting points. The rear bar on my 71 with poly end links makes a huge difference in body roll. You will appreciate the difference it makes on your car. I prefer the look of Blue's install to the one on my 71. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-360290 Share on other sites More sharing options...
July 1, 201113 yr Author comment_360292 Randy, my rear sway bar has the hanger pieces mentioned above, so I can mount it like the pics show. I believe that you can mount the rear sway bar both ways, but most people like to install like the photos above as a preferred method, instead of drilling into the floor pan. However, the rear sway bar I got is bigger than my front sway bar, so am waiting on getting a beefier front sway bar to install before I add the rear one. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-360292 Share on other sites More sharing options...
May 26, 201212 yr comment_391189 I am looking for a rear sway bar that will fit the mountings in the photo above (already have the "hanger pieces" with the tabs for mounting it in the car). The URL where this photo came from "http://jdm-car-parts.com/customizing/bresuspention-techniques-type-rear-swaybar-on-240z/" says that this was a BRE sway bar and that there was also a similar ST one that are NLA. Does anyone know where you can get a similar sway bar today? Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-391189 Share on other sites More sharing options...
June 4, 201212 yr comment_391994 I have the one pictured above, which I believe was that originally offered aftermarket. But they had one that came out later to be mounted like the OEM types used on the 260Z and 280Z. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-391994 Share on other sites More sharing options...
June 4, 201212 yr comment_392022 Check with MSA. They may be able to help. Or send Esprist an email and see if he can get you one. I got my BRE set up from him. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-392022 Share on other sites More sharing options...
June 4, 201212 yr comment_392046 My addco rear sway bar are as Bryan described. OEM type rear bar 7/8" front 1". I have the original instruction sheet. Link to comment https://www.classiczcars.com/forums/topic/39512-how-to-install-rear-sway-bar/#findComment-392046 Share on other sites More sharing options...
