Can someone else weigh in on this. I am not sure what the advantage was of dual points but I believe they were considered superior to the single point distributors. jlp
The dual point distributor for the Z is (was) only used in automatic transmission cars. The two sets of points operate separately, but only one set at a time. One set is has different base timing setting than the other. One set is used normally and the other set is used under certain conditions to lower emissions. This is not a performance enhacing set-up.
The hot rod dual point set-up is used to increase dwell which helps high rpm performance with high power engines. The two sets work together, on set making the circuit and the other breaking the circuit. The advent of electonic ignition and computer controlled (adaptive) dwell seems to have place the dual point set-up in the closet next to the phonograph.
Overall very informative, thanks. The dual point distributor I have came off a 1973 manual transmission car and is purely mechanical advance. It must be an aftermarket performance distributor. jlp
The Pertronix system has an adjustment for the air gap between the pick-up and the magnetic trigger (the black plastic ring you press onto the points cam). Perhaps the gap is too large?
Check the voltage at the ballast resistor (with respect to ground). One side should be battery voltage, about 14 volts when the eninge is running. The other side should be about 9 or 10 volts at idle and rise to about 12 volts at high engine speed. Low voltage on the 14 volt side indicates a bad connection somewhere (or a weak charging system). Low voltage on the 9 volt side indicates a bad or incorrect ballast. The original ballst should be 1.6 ohms when cold (68 degrees F). The Pertonix coil might need a different value ballast. Check with Pertronix.
If the voltage at the 14 volt side of the ballast is low or unstable check the connectors in the primary circuit. There are a lot of connectors involved, mostly under the dash. Check them all. The factory service manual shows where each one is.
The primary circuit runs through:
The fuse box (and a fuse) - check the fuses
The ingition switch
The ballast resistor
The tachometer
A lot of connectors
If you have all the parts, put the points back on. If it runs properly the Pertonix module is bad. Another test of the Pertronix module would be to put in another Pertonix that you know to be good and see of anything changes.
The coil could be damaged from overheating if the car was run too long without the ballast resistor. Try a different coil.
With the Pertronix set up it is recommended by Pertronix NOT to use the ballest resistor with a 40,000 volt coil (3 ohm), you will need to connect those two wires together or to put a jumper in to by-pass the ballast resistor. I just installed Pertronix w/3 ohm coil and mine is dead on. The first one I installed from them was defective and had to go back to points. You may want to remove the Pertronix entirely and install points (along with your ballast resistor and correct coil - and see if that fixes things. If it does, you will know it's your Pertroinx set up
