Posted May 13, 201113 yr comment_355609 Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/ Share on other sites More sharing options...
May 13, 201113 yr comment_355614 As a kid, I remember seeing these in the late 60's in our 'wish book', J.C. Whitney. Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355614 Share on other sites More sharing options...
May 14, 201113 yr comment_355676 Has anyone used one of these? It seems, by the nature of toilet tissue, that it would break down and clog up every passage in your engine. jlp Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355676 Share on other sites More sharing options...
May 14, 201113 yr Author comment_355677 Use only when your car runs like crap. Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355677 Share on other sites More sharing options...
May 14, 201113 yr comment_355679 Wow the Franz Oil Filter!I used this back in the 80's on my 77 Datsun pickup. I don't remember ever having a problem with it. As I recall it was recommended to use their brand of paper as it was a lot more dense than normal t-paper. I did replace it with standard t-paper and it ran fine it didn't break down. When I did go to replace the roll, it was just a in tact oil-soaked roll of toilet paper.Like I said...it ran fine. This was in the mid 80's. Would I use it again? I doubt it. I wish I could offer solid evidence either way. It appears to be used extensively in the trucking industry with good results but I defer those who are better informed.Dave Ruiz Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355679 Share on other sites More sharing options...
May 14, 201113 yr comment_355680 If you need a thinner weight oil...just add Exlax!NEXT... Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355680 Share on other sites More sharing options...
May 14, 201113 yr comment_355718 I thought you took the cardboard tube out when using these Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355718 Share on other sites More sharing options...
May 14, 201113 yr comment_355730 Toilet paper; it's not just asswipe anymore. Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355730 Share on other sites More sharing options...
May 16, 201113 yr comment_355951 My dad used to use a kotex (or that "type" of product) in the old chevy. Never thought a thing about it at the time. I'll have to check the old Chrysler and see if it has a roll in it. (it doesn't get driven much). I know the old Volvo uses a cartridge but a roll "can be used in an emergency". One wouldn't think the oil could get through in a timely manner and it would just go through the bypass. Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355951 Share on other sites More sharing options...
May 16, 201113 yr comment_355954 IdahoKidd said: One wouldn't think the oil could get through in a timely manner and it would just go through the bypass.I don't believe it could actually filter the oil through the roll of toilet paper.JLP Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355954 Share on other sites More sharing options...
May 16, 201113 yr comment_355957 JLPurcell said: I don't believe it could actually filter the oil through the roll of toilet paper.JLPThat's what they claimed it did 'back in the day'. Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355957 Share on other sites More sharing options...
May 16, 201113 yr comment_355965 I used them. There 50's 60's tech, yes they work, ment for cars that had no filter, no I would not want to run one now. Not even if I thought they were cool. Buy an Oberg, same idea, newer tech. Link to comment https://www.classiczcars.com/forums/topic/39557-stilko-external-oil-filter-with-toilet-paper-replacement/#findComment-355965 Share on other sites More sharing options...
