Well I am replacing my clutch slave and master to hopefully fix the problem of my clutch pedal not getting any pressure. Well the slave is replaced and the problem still persists, so while trying to get the master off, the fitting for the line won't come off which in terms has stripped it. Look likes I need a whole new line, but I need the size and length of the main line so I can make one.
Any help on the line issue, or just my clutch issue in general would be wonderful. (and yes I tried bleeding the system to gets some pressure back in the pedal but that didn't work.)
Measure it with a chunk of 14-16 gauge wire snaked along its length. its 3/16 brake line with 10 x1.00 mm threaded brake line nuts. Any decent car parts shop has premade lines, just need one thats long enough and maybe a tubing bender.
Edited by zKars
