Posted May 17, 201113 yr comment_356094 hey, im dropping a f54/p79 in my 77 280, im wondering if im missing a part or if this is for add-on purpose. around the oil filter theres four holes that look like something should be mounted there, i could be wrong though.any ideas? also i read somewhere this combo is 81-83, is that correct? ps, thats not my nasty looking engine, i found it on google Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/ Share on other sites More sharing options...
May 18, 201113 yr comment_356114 That is strange, I never noticed that before but looks like all f54 blocks have those bosses drilled and tapped for something that may have been used in a different market in some other nissan variant. If it does not interfere with the oil filter I wouldnt worry about it. Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/#findComment-356114 Share on other sites More sharing options...
May 18, 201113 yr Author comment_356126 awsome, thank you. Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/#findComment-356126 Share on other sites More sharing options...
May 18, 201113 yr comment_356153 That's likely for the same type of adapter that was in the 810/RWD Maxima on the L24E engines. Not sure about the ZX's but it appears to have been done for clearance on the 810. I points the filter upwards an toward the front of the car. Can't see the adapter in this picture but you can see how the filter angles up between the vacuum cannister and the windshield washer bottle insted of straight out of the block. Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/#findComment-356153 Share on other sites More sharing options...
May 18, 201113 yr comment_356167 On my diesel block (SC'd petrol stroker project) the same arrangement exist. I'm using the factory remote oil cooler adapter from a 280ZXT. It has an o-ring to seal against the block where the oil filter seal normally rides. The top threaded hole is used to 'locate' the adapter. The center oil hose fitting is tightened (passes through adapter and threads into the block) to secure the adapter tightly cinching up tet o-ring I mentioned. I'm certain that the other threaded bolt holes allow for the same purpose depending on what adapter you're using and where you want the oil filiter to sit. Edited May 18, 201113 yr by ezzzzzzz Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/#findComment-356167 Share on other sites More sharing options...
May 19, 201113 yr Author comment_356202 thanks for the info. anyone know if the year range is correct? motorsport is showing different plugs for different years of the injected motors. dont really see why they'd be different but i just want to make sure, the info i got was from datsunzgarage.comhttp://www.thezstore.com/page/TZS/CTGY/SEIC01G Link to comment https://www.classiczcars.com/forums/topic/39607-f54-oil-filter-adapter/#findComment-356202 Share on other sites More sharing options...
