More lines and more
240260280z
Formed and ran lines:
- 1/4" fuel return
- 5/16" fuel send
- 3/16" fuel vapor
Refurbished fuel line clips
- wire brushed using drill
- drilled out and tapped broken bolts
- oshpho dip
- paint
Continued Rebuilding front hubs
- Brembo rotors installed
- Wheel bearing tension set and cotter pins installed
- Tension/Compression rod ball and socket installed
Removed over-spray on aluminum s/n plates
Refurbished and installed brake pressure switch
Refurbished Hand Brake assembly
Picked up foil backed bubble wrap and adhesive for sound insulation and thermal insulation
Whew... even more to do tomorrow. Lots of fun.
