I bought the Z Therapy carbs and manifolds for use without the water and those ports have a plug in them. Perhaps for appearance? One would think it would just be an open hole and wouldn't matter much though....
I just removed the water line from my intake last weekend. The water path is isolated from the intake so the open ports won't impact the funcionality of the intake, but I plugged the ports just to keep any debris out in case I had second thoughts down the road. I stuffed some large rubber vaccum caps in the holes backwards (open end in). Proper fitting aluminum plugs would be ideal, but the caps look nice and they shouldn't go anywhere.
Bruce, if that was coming from anyone else but you, I'd call balogny.
Is the inner thread size metric? The standard plugs I bought won't thread in.
P.S. nice work on your carbs, my neighbor has a set, they work and look awesome.
No, actually you can go ahead and throw the BS flag as that's what it was.
What Steve uses is small freeze plugs with some teflon tape or some such to hold 'em in. Perdy and silver and chicks dig'm.....
