Intake water tube removal.
Rocket88
I just removed the water line from my intake last weekend. The water path is isolated from the intake so the open ports won't impact the funcionality of the intake, but I plugged the ports just to keep any debris out in case I had second thoughts down the road. I stuffed some large rubber vaccum caps in the holes backwards (open end in). Proper fitting aluminum plugs would be ideal, but the caps look nice and they shouldn't go anywhere.
Bruce, if that was coming from anyone else but you, I'd call balogny.
Is the inner thread size metric? The standard plugs I bought won't thread in.
P.S. nice work on your carbs, my neighbor has a set, they work and look awesome.
  • Who's Online   1 Member, 0 Anonymous, 739 Guests (See full list)
