Posted May 19, 201113 yr comment_356281 Hi,My local Nissan dealer can only order newer part numbers. I need the 4 flange bolts and nuts on each side of an early R180 differential from a Jan 71 240z. The bolts are somewhat unique and have a quadrant shaved off for clearing the round plate that protects the seal.Would anyone happen to have a part number?Thanks! Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/ Share on other sites More sharing options...
May 19, 201113 yr comment_356283 Phil, Try looking here. The picture isn't too good, but you might be able to find it. Of course, I just remembered that I have the parts catalog. This scan should work better: Edited May 20, 201113 yr by SteveJ Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356283 Share on other sites More sharing options...
May 19, 201113 yr comment_356284 I get 38226-21000 for both the halfshaft and driveshaft bolts for a R180. Not sure if that is a good number anymore. Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356284 Share on other sites More sharing options...
May 20, 201113 yr Author comment_356294 Thanks, I got Differential to 1/2 shaftpart (34) bolt 38228-21000 here: http://carfiche.com/fiche009/s30/5/g15.gifDifferential to drive shaftpart (2) bolt 01111-00051 here: http://carfiche.com/fiche009/s30/5/g06.gifpart (3) nut 01223-00041 Drive shaft to hubpart (19) bolt 39628-E4100 here: http://carfiche.com/fiche009/s30/5/i16.gifhowever my local dealer typically can not use these numbers. Is there an on-line cross reference anywhere?I bought a Nissan parts tool CD but it only went back to '83. Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356294 Share on other sites More sharing options...
May 20, 201113 yr Author comment_356295 just searched the part number and got this Looks like a new bag and new part number Dang Hybrid Z doesn't allow external links to photos... great Z community spirit.... NOT Edited May 20, 201113 yr by Blue HyrbidZ.org sucks Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356295 Share on other sites More sharing options...
May 20, 201113 yr comment_356296 How many do you need? I probably have some left over from my parts cars. Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356296 Share on other sites More sharing options...
May 20, 201113 yr Author comment_356297 Thanks! I should be able to get locally now that it seems to be a current part number You are kind! Link to comment https://www.classiczcars.com/forums/topic/39625-nissan-part-request-for-early-differential-flange-bolts/#findComment-356297 Share on other sites More sharing options...
