Heater water cock replacement
Utah Hawkeye
I have a 1980 280ZX with air conditioning. The water **** is leaking and needs to be replaced. Mine has a copper lead that goes into the heater unit somewhere under the heater core. The only one I've seen for sale is the water **** without the copper "sensor" thing. SO... does anyone know what will happen if I use the the water **** without the sensor to replace mine?? What will I loose by not having the sensor?
This is what I have (see page 8)
http://www.atlanticz.ca/zclub/techtips/zxclimatconversion/part1.pdf
This is what I can find to purchase
http://www.thezstore.com/page/TZS/PROD/SHC03/16-7648
Any help is appreciated.
I'm not sure how it would affect the A/C compressor 'cuz the sensor only attaches to the water ****. But, maybe without the sensor it would open the water **** when the A/C is on. IDK I'll check with MSA when the wake up on the west coast. They used to sell both water cocks. Maybe someone there knows. Thanks for your input.
  • 1 month later...
  • Who's Online   1 Member, 1 Anonymous, 608 Guests (See full list)
