August 16, 201113 yr comment_364145 freaken awsum Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-364145 Share on other sites More sharing options...
August 16, 201113 yr Author comment_364148 Hi, If some one has a original (JDM assembly), could they have a look at the out lens please, and see if it has this 'step' ( see picture ), if not, what size is the 'step' in the outer chrome ring, I'm trying to figure out if the lens is different, or the chrome ring is different than the Aus 240K if you have a nice clear picture, that would help as well. Nigel Edited August 16, 201113 yr by Noddle Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-364148 Share on other sites More sharing options...
September 22, 201113 yr Author comment_367074 Bump, can someone with original (JDM assembly) have a look , please .. Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367074 Share on other sites More sharing options...
September 22, 201113 yr comment_367104 ill check tomorrow Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367104 Share on other sites More sharing options...
September 22, 201113 yr comment_367166 Put me down for a set please Noodle Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367166 Share on other sites More sharing options...
September 23, 201113 yr comment_367206 Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367206 Share on other sites More sharing options...
September 26, 201113 yr Author comment_367364 Thanks for this,I will need to look at my setup to where the difference are,but it looks like the outer lens sits lower in the housingNigel Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367364 Share on other sites More sharing options...
September 26, 201113 yr comment_367397 if you need more picks ask :> Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-367397 Share on other sites More sharing options...
November 7, 201113 yr comment_371095 Wow, awesome work on doing this, so much patience involved! Did you do the revised versions? Did they come out ok? Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-371095 Share on other sites More sharing options...
November 8, 201113 yr Author comment_371270 To be honest, I have been a bit slack and have not done anymore besides cutting up a test lens and seeing how I can make it work,I think the OEM lens is a different shape at the base, which would be hard to reproduce with out one.I know what I have will work with a 4 door rear tail light panel, but with a 2 door ( the one with the larger outer surround ) need to be spaced to fit.Nigel Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-371270 Share on other sites More sharing options...
November 22, 201113 yr comment_372499 Awesome, well I'm keen to see how you go with the "final edition" for the coupe ones Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-372499 Share on other sites More sharing options...
April 17, 201212 yr comment_387348 Any progress on this noodle? Link to comment https://www.classiczcars.com/forums/topic/39647-jdm-style-tail-lights/?&page=6#findComment-387348 Share on other sites More sharing options...
