Mikuni's on a short intake, with a short air horn is 10 inches....I have 8 inches of room straight out from the head.
Is anyone familair with who makes this fuel injected system?
Kinsler Hilborn Fuel Injection Datsun 240Z, 260Z, 280Z
Made a system not like the above but here is a link to a set that sold on ebay.http://cgi.ebay.com/ebaymotors/Kinsler-Hilborn-Fuel-Injection-Datsun-240Z-260Z-280Z-/160552313098
It looks like it is made by ITB...just what you see there is $2K.
I raised the motor as high as it would go, moved it as far over to the driver side as it would go and with the 260Z spacer and a few hits with the ball peen hammer, I think it may just make it. I will need to work on the motor mounts first, trans mount second and then do the final fitting of the intake. I am going to make some 1/4 inch plate spacers for the motor mounts, to give me some room to make some final adjustments. This will take some time for me to do, but I will create a new post when completed.
Millboard 1/8" thick. http://www.mcmaster.com/#9362k11/=cgp8pj Paint it with Stainless paint to seal it inside and out - 7721T37 at the same McMaster site.
Edited by John Coffey
John has a great solution as always!
If you want to drum up a sheet/flat piece of bakelite from an old household object then it may work as a substitute.
This material may even be what the original spacers are made from. Have a look: http://en.wikipedia.org/wiki/Bakelite
