Here's what I'm looking at getting:
1979 280-zx 2+2 with five speed. 140xxx miles on it.
I want the five speed in the 260z. Besides getting a new clutch kit, will those parts swap over exactly into the 260z? Will I need to do some adjustments or anything? Any additional parts need to be ordered?
https://www.classiczcars.com/forums/topic/39661-tranny-swap-compatibility/
If you search transmission swap, 240Z, or 280Z on Google, this forum and other forums you will find a lot of good reading. This topic comes up all of the time and there are several good write-ups around the internet.
The 2+2 probably has the 240mm clutch and flywheel, and your 260Z has a 225 mm setup. So you would need to move the flywheel over also.
