1
Disconnect spark plug wires and fold back out of the way.
2
Remove spark plugs.
3
Disconnect fuel lines (send and return) at fuel rail near front of the head.
Observe all high pressure fuel safety precautions.
4
Disconnect valve cover vent hose.
5
Remove valve cover.
6
Put transmission in neutral.
7
Use short 27mm socket to turn engine at crank. (when viewed from standing in front of car, turn crank clock wise)
8
Turn until timing mark on damper is lined up with "0"
