Email logins are now active ×
What size clutch on 280zx
If it's the 2+2 in your other thread, then that car should have the 240mm flywheel.
2 seaters had the 225mm flywheel.
Make sure you match whatever flywheel you use. The PP and bearing collar are different between the two.
  • Who's Online   2 Members, 0 Anonymous, 578 Guests (See full list)
