June 8, 201113 yr comment_358139 ...I now have a very loud screech in the cam near 4 and 5. Since machining the head I may have valves that are tight and that would explain a slightly jumpy vac gauge with 18 inches...Did you (or the shop) pull the cam towers when you had the head machined? If so, the cam might not be spinning freely, causing the noise. If the towers were off, pull your rockers and the timing chain and make sure the cam spins freely. If the cam is binding, it will destroy the cam and towers. Link to comment https://www.classiczcars.com/forums/topic/39705-put-your-thinking-caps-on/?&page=2#findComment-358139 Share on other sites More sharing options...
June 10, 201113 yr Author comment_358304 The machineshop left the towers on and only took off 015 so I did not need shims. When I pulled the valve cover i found the oiler tube broken off for the last two cylinders and laying upright on the right of the head. I am doing a cold valve adjustment and making a sling using a universal tailpipe kit to shore up the tube on both ends. will post pics when completed. Link to comment https://www.classiczcars.com/forums/topic/39705-put-your-thinking-caps-on/?&page=2#findComment-358304 Share on other sites More sharing options...
June 10, 201113 yr comment_358306 The machineshop left the towers on and only took off 015 so I did not need shims. When I pulled the valve cover i found the oiler tube broken off for the last two cylinders and laying upright on the right of the head. I am doing a cold valve adjustment and making a sling using a universal tailpipe kit to shore up the tube on both ends. will post pics when completed.Ahh, yes. The oiler bar must me checked and cleaned anytime it's out. They have been known to crack and break off like that. Hopefully it didn't ruin the cam, rockers, or tower. Link to comment https://www.classiczcars.com/forums/topic/39705-put-your-thinking-caps-on/?&page=2#findComment-358306 Share on other sites More sharing options...
June 10, 201113 yr comment_358336 A few years ago, I noticed an end of my oil bar broke off on my 240Z. Found the piece in my oil pan! Link to comment https://www.classiczcars.com/forums/topic/39705-put-your-thinking-caps-on/?&page=2#findComment-358336 Share on other sites More sharing options...
