Posted May 29, 201114 yr comment_357137 Hello everyoneI am needing a 1982 280zx turbo AFM, wire loom and ecu. I have a 1975 280z that has an '82 turbo transplant. Problem is that the air to fuel ratio gets lean at higher rpm's. Which is why my pistons are melting and broken:tapemouth. So I figure this may be the best solution, unless someone here has a better idea with what I have to work with.Note, I have not look hard into mega squirt yet. but lets start here first.Thanks.Big Al. Link to comment https://www.classiczcars.com/forums/topic/39715-1982-turbo-zx-afm-wire-loom-and-ecu/ Share on other sites More sharing options...
