Posted May 29, 201113 yr comment_357178 Can anyone confirm what the proper vacuum reading should be on a carbureted L28 at idle? Thanks Guy Link to comment https://www.classiczcars.com/forums/topic/39719-proper-vacuum-readings/ Share on other sites More sharing options...
May 29, 201113 yr comment_357181 17-20 "Hg on an EFI. I assume it will be the same on a carb: http://atlanticz.ca/zclub/techtips/vacuum/ Link to comment https://www.classiczcars.com/forums/topic/39719-proper-vacuum-readings/#findComment-357181 Share on other sites More sharing options...
May 29, 201113 yr Author comment_357192 Thanks Blue......that's just what I was looking for! Anyone know where to get a set- up like the one used to hook up to the brake booster port.........like the step down in Blue's post? The booster port is too big of a diameter for the hose on my vacuum gauge. Guy Link to comment https://www.classiczcars.com/forums/topic/39719-proper-vacuum-readings/#findComment-357192 Share on other sites More sharing options...
