Just tore down a short block. The folded mesh material in the block where the tube to the PCV valve has rusted to mush. Is there a synthetic material substitute that can be used to replace it?
Probably, but you can fold up a replacement out of metal fly wire and it will last the life of the engine.
It is a very efficient oil/vapor separator so don't be tempted to use anything that may clog up and render it useless.
Thanks!
I was thinking stainless steel mesh may be the way to go. The stuff that was in the L24 turned into iron crud/mud/crust above the bottom 3 folds.
Fortunately I found a spare from an L28 block that I took apart and forgot about. I'll degrease and inspect.If it is no good then Nissan dealer is my friend.
